Dry skin: care and treatment
February 14, 2013
  • Dry skin: care and treatment
  • Nursing
  • Masks and Makeup
 dry skin
 Few things can be worse than the dry, itchy skin. Dry skin can appear at any time of year, but most people are faced with this problem in the winter. Why is that? In the cold season due to low air temperature and humidity, strong winds and heating in homes, the skin loses the natural lipid layer of the skin that normally protects it from dryness. To skin remained did not dry, you need to first of all take care that they do not allow it to lose moisture.
Wash with water at room temperature
Hot water dries the skin, so it is best to wash with water at room temperature. If you find it difficult in winter to observe this rule, take a warm shower, but once a day, and only for five minutes. It is also recommended to give up hot baths: immersion in hot water, combined with drying chemicals (foam and salt bath) - it's fun for you, and torture to your skin.
The same rules apply to hand-washing - just wash them with warm, not hot water.
Moisturize your skin immediately after washing
Apply moisturizers immediately after having taken a shower or wash your hands - this time the skin is best absorbs nutrients and moisturizing agents.
Exfoliate your skin once a week
Moisturizing creams are better absorbed in the well-cleansed skin, which is not too thick layer of dead skin cells. However, you should not use exfoliating too often - for a good result rather than once a week. For example, use of the salt scrubs or sugar, as well as natural oils, which are also well clear, and at the same time and moisturize the skin.
Buy a humidifier
To remain well hydrated skin, the level of humidity should be at least 30%. In the room where the heating turned on, the humidity may be only about 10%. To increase the humidity, use humidifiers - it is desirable to put them into every room, and above all - in the bedroom.
Do facials
Moisturizing Mask - an obligatory element of care for dry skin. Whether you are using a commercial or homemade masks - most importantly, to do it on a regular basis, otherwise there will be little benefit.
Take good care of hands and feet
The skin on the hands and feet in winter can become very dry, but we often do not notice it, focusing on the care of the person.
In winter, apply a moisturizer and be sure to wear gloves before you go out. Several times a week before going to bed Dreams: how to understand our dreams  Dreams: how to understand our dreams
   copiously smear moisturizer hands and feet, and sleeping in cotton socks and gloves - it will provide deep hydration.
Do not forget the lips
Licking his lips, you do not moisturize them, but rather help them to dry faster. Lips lose moisture faster than other parts of the body, so they need help - Regularly lubricate them balms, and before going to bed - natural oils.
Protect your face
If you have very dry skin, maybe you should give up washing with tap water. Instead, use a mild detergent solution which does not need to wash or mineral bottled water.
Take fish oil
Fish oil can improve even very dry skin. On average, six weeks the skin becomes smoother, cease to peel off, it disappears feeling of tightness. Hair and nails are also starting to look better How to look better: the secrets of the natural charm  How to look better: the secrets of the natural charm
 . Just a couple of fish oil capsules a day can almost create miracles. If you do not forget about the rest of the rules of skin care, it will soon have to hear her address mass deserved compliments Compliments and their meaning: do not mistake the words  Compliments and their meaning: do not mistake the words
Bath with soda for weight loss - some recipes that you did not know
December 15, 2014
 bath with diet soda
 Many people use baking soda for making dough, to remove stains from various surfaces and, sometimes, for the treatment of heartburn. But not everyone knows that applies even bath with diet soda.
 alt
How does slimming bath with baking soda?
Supporters of losing weight with the help of baths with soda claim that they help to lose weight by cleansing the body of toxins, stimulate lymph flow and metabolism in the deeper layers of the skin. As a result, people will be easier and faster to lose extra weight - of course, under the condition that he would take a bath regularly. Indeed, many people who took soda or soda-salt bath for weight loss, noted that their weight after a bath decreased by 0.5-1 kg, and in some cases, weight loss can be even more significant.
The effectiveness of baths with baking soda for weight loss Soda for weight loss - without research  Soda for weight loss - without research
   It has not been studied, but experts are quite skeptical about this tool.
According to them, after a reduction in weight may be due to the bath only perspiration begins under the influence of hot water, baking soda and salt, which is also often added in such baths. The weight lost by the water usually returns quickly, and fat burning soda bath, apparently do not have a direct influence. However, if they really speed up metabolism, possibly with the help of their process of losing weight faster and go - but only if a person eats moderately and moves a lot.
It is also possible that the soda bath can help to cope with cellulite due to its ability to stimulate lymph flow - in this regard, their effect is reminiscent of the effect of lymphatic drainage massage, although, of course, he expressed much weaker.
 alt
How to take a bath with diet soda
  • Recipe 1. Fill the bath with hot water. Pour into a large bowl six or seven tablespoons of baking soda and mix thoroughly. Pour a cup of water in the bath. Take a bath should be between twenty and forty minutes.
  • Recipe 2. Add hot water bath one or two liters of water, which dissolved the three quarters of a cup of soda and the same amount of sea salt. If this bath does not cause skin irritation, the next time can be added to the water over the whole cup soda and salt. Subsequently, increasing the amount of soda and salt is not necessary.
  • Recipe 3. Add half a cup of water, baking soda and a quarter cup of Epsom salts. Take a bath for at least thirty minutes.
To increase the effectiveness of the bath with baking soda for weight loss and speed up the elimination of toxins, before they go to the bath, a cup of mint tea.
Soda bath to not only help lose weight, but also make the skin more smooth and elastic, first remove dead skin cells using a scrub brush or dry.
Besides sea salt and Epsom salts in the soda bath can be added:
  • Essential oils. They do not promote weight loss, but it helps to relax, improve your mood, and some of them even make it easier to remove the signs of depression and headaches. When choosing essential oils are best guided by their own preferences - if the oil you like, it will do you good;
  • Ginger. If you add the ginger Ginger and the most unexpected, but pleasant useful properties  Ginger and the most unexpected, but pleasant useful properties
   in a hot bath with baking soda, it will accelerate the elimination of toxins, improve blood circulation in the upper layers of the skin and increase perspiration (by the way, had to sweat even more, you can lay in the bath, drinking hot ginger tea). In addition, the bath with ginger can be taken at the first signs of cold - pungent ginger can significantly speed up the recovery. You can just add soda bath two or three pinches of ground ginger, or one or two tablespoons of grated ginger root, but it is better just to pour into her cup of strong ginger tea. To make a tea, pour a tablespoon of ground ginger or two tablespoons of finely chopped ginger root boiled water and let stand for 5-10 minutes;
  • Black clay. Spa with black clay has long been used to combat excess weight and cellulite, and in combination with soda clay can be even more effective. Add the hot water bath, and half a cup of baking soda the same amount of dry black clay; Stir the water.
 alt
Safety measures
People suffering from hypertension and other disorders affecting the cardiovascular system, before you take a bath with baking soda for weight loss, you must consult a doctor. People with sensitive skin Sensitive skin: causes and care  Sensitive skin: causes and care
   soda-salt baths can cause irritation of the skin; soda baths are usually safe. Those who have very dry skin Dry skin: care and treatment  Dry skin: care and treatment
 , Baths with soda best avoided - they may make the skin more dry, cause a feeling of tightness and strong exfoliation.
Article Tags:
  • bath
  • Weight loss
Hair Loss - a rather delicate problem
About a woman's breasts say a word ...
Masseurs for weight loss: whether they can be an adjunct to diet and stress?
Breast massage - how to achieve good results
Waxing - effective, but the disease
Compression stockings - check with your doctor
Sweating at night - what is the cause and how to get rid of it
Anti-cellulite massage or lymphatic drainage banks
Spots on the head hair - pleasant enough
How to treat cracked heels - a variety of ways
How to head massage: relieves pain and stress
The treatment of pressure ulcers in the home - notes
How to remove the stomach after childbirth: is possible to return all
Why do I need a bra: Secrets lingerie
Aevitum skin - has the most beneficial effect
Sunscreen is not just for the beach
How to prevent and eliminate dry hair - a few simple tips
Hair Restoration: help correct care
Sauna and health: the benefits and harms of bath procedures
Recipes of Morpheus, or how to avoid sleep problems
Linseed oil for the body - finished natural cosmetics
Linseed oil for the breast - does it make sense?
Healthy skin - daily program for skin care
Exfoliation of dry skin: an effective way to fight cellulite
Care | Dry skin: care and treatment
Hair oil - how to do massage with oils
Stem cells: on the edge of scandal
If you need to quickly get in shape, or how to remove belly fat in a short time
Seborrheic | Hair Loss - a rather delicate problem
Shiatsu Massage | Hair Loss - a rather delicate problem
Naturopathic Treatment | Hair Loss - a rather delicate problem
Androgenic | Hair Loss - a rather delicate problem
Waxing: delicate solution to the problem of unwanted hair
Vaseline: old friend
Habits that preserve human life
Cleaning the skin - what tools should I use?
Foot Care - Beauty and Health
Traditional methods | Correction of breast without surgery: beauty does not require victims
Cellulite treatment - no illusions
Anti-cellulite massage - beautiful skin
Hand Care - hide your age
Caring for different types of skin: a guide to action
Artificial nails - acrylic, gel and silk
10 common misconceptions related to health and medicine
Anti-stress massage of the head and neck: a pleasant relief from headaches
Acrylic nails and Health
Bubble baths - wonderful wellness treatment
Vaginal lubricants - delicate cosmetics
10 ways to skin care after thirty
Clay treatment - mineral Rainbow Health
14 tips for strong and healthy nails
Dirty Dozen - twelve most common skin irritants
7 facts about the French manicure, you need to know
Whirlpool - water treatment in the service of medicine
The choice of protective equipment from the sun: elegance at its zenith
Tanning - how dangerous it is?
Beautiful hands - do not forget the cream
Return slim figure: how to remove belly fat after giving birth
20 steps to the sexiest legs
Intimate cosmetics - is it worth it to use?
Healthy nails - do not neglect the daily care
How to make a beautiful and healthy legs - simple advice on hygiene
Home waxing - an inexpensive alternative for busy women
How to cope with sweat: the hot season without embarrassing situations
How to remove cellulite: sports therapy
Hardening of cold water - it makes the body work
Sunblock - a protection index is right for you?
How to remove belly fat: tips and tricks
How to strengthen the nails at home - the procedure "manual" Beauty
How to get the perfect tan without harm to health
How to sunbathe: the secrets of the perfect tan
How to avoid heat stroke - protects not only the head
How to remove the stomach after pregnancy: a return to the old form
Beautiful skin - achieving
Douches - effectiveness is proven time
Foot Cream - how to choose the right one?
How alcohol affects the condition of the skin?
Brittle nails - Prevention and Treatment
The best cream for hair removal - an effective tool
Honey massage and its amazing properties - the most pleasant procedure
The myths about skin care: the dependence on cosmetics
Facial massage: beauty with their own hands
Lyuminoterapiya - healing light to tired organism
How to strengthen the nails: simple tips every day
Massage Therapy - when it is needed?
Lyuminoterapiya against seasonal depression
Lymphatic drainage massage - beauty in a bottle
Head massage - the best way to relax
How to rejuvenate your body - combine business with pleasure
Manicure - improving the health of their nails
Lipossazh - body shaping without surgery
Office of the disease: all treated in one motion
Hair extensions - and still uncomfortable to sleep
Artificial nails: they would like to hide from you workers nail salons?
Unusual ways to use Vaseline - use in the household
The health risks associated with artificial nails and manicure
Improperly made gel build-up and damage to the nerves
Folk remedies for cellulite massage, bath care products
Body Rejuvenation: aging - no!
Skin care during pregnancy - which products are best avoided?
Myths and facts about artificial nails - actual questions and useful answers
Types of skin care and features
Swimming in cold water - the strengthening of the body
Artificial nails: benefit or harm
Pedicure: healthy nails - beautiful legs
Nail care - little tricks
Stretch marks on thighs - the basic principles of the struggle
Full updated guidance on beauty and style in hot weather
Tips for healthy feet
Stretching: Causes and Treatment - can I get rid of them forever?
Art manicure and nail health risk
The aging of the skin - from what it depends on?
Black clay cellulite: how to deal with "orange peel"
Acupressure head: nice and helpful
Dry brush exfoliation: a pledge of soft, beautiful skin
Massage technique: mash and strokes
Foot care for men leading different lifestyles
Heatstroke - unexpected and dangerous
Care for beautiful legs how to do a pedicure at home
The most serious health problems for office workers
Caring for sensitive skin - protection every day
Chiromassage - full control over the senses
Physical therapy - an effective recovery of the body
French manicure - high fashion effortlessly
Side Effects | waxing - effective, but the disease
The feet and associated problems | Foot Massagers - how to effectively relieve fatigue?
Outside | The most common skin problems and their solutions
Recommendations | How to prevent and eliminate dry hair - a few simple tips
Impact | Solarium: harm or benefit?
Controlled tan | Solarium: harm or benefit?
Applications | Glycerin: miracle ingredient for skin and hair
Natural oil | Sun - the natural beauty of your skin
Products | Healthy skin - daily program for skin care
How to cook | Sun Oil - the natural beauty of your skin
Nutrition | Healthy skin - daily program for skin care
Methods | How to care for dry skin: a lot of useful advice
Benefits | Exfoliation of dry skin: an effective way to fight cellulite
Features | Stem cells: on the edge of scandal
Applications | Vaseline: old friend
Contraindications | Waxing: delicate solution to the problem of unwanted hair
Proper care | Shoe leather - what tools should I use?
Diets and Treatments | Cellulite treatment - no illusions
Problems | Healthy Legs - tripping
How to prevent pain | Healthy Legs - tripping
Techniques | Thai massage - restore the energy balance in the body
Theory | Thai massage - restore the energy balance in the body
Lipolysis | Correction of figures: the options to fight obesity
How to Choose | Hair Balm - part of the care program
Pamper yourself | 10 ways to skin care after thirty
Applications | Clay treatment - mineral Rainbow Health
Symptoms | Hyperthermia - when the body is overheated
Check razor | How to get rid of the irritation after shaving: soft skin without problems
Heatstroke | Hyperthermia - when the body is overheated
Effect | hardening cold water - make the body work
Home Remedies | How to cope with sweat: the hot season without embarrassing situations
Tips | How to keep in shape holidays - just do not do not panic!
Care and Exercise | 20 steps to the sexiest legs
Care | How to help the skin burned - some simple ways to cope with sunburn
The art of disguise | ready for the season of short skirts: how to make beautiful legs?
Warnings and consequences | Hot waxing - an inexpensive alternative for busy women
Treatment | How to help the skin burned - some simple ways to cope with sunburn
Principles and Methods | hardening cold water - make the body work
Indications and contraindications | Douches - effectiveness is proven time
How to prevent | How to avoid heat stroke - protects not only the head
Ingredients | depilatory cream - delicate hair removal
Secrets | Beautiful skin - achieving
Applications | Lycopene: Natural ingredient for youthful skin
Products | Lycopene: Natural ingredient for youthful skin
Lyuminoterapiya practice | Lyuminoterapiya - healing light to tired organism
Forms | Massage - not only relaxing, but also treats
Efficiency | Massage - not only relaxing, but also treats
Massage another person | Head and neck massage: home workshop
Equipment | Cosmetic massage: beauty with their own hands
Indian Head Massage | head massage - the best way to relax
Shiatsu | Massage head - the best way to relax
Contraindications | Massage Therapy - when it is needed?
Forms | Office of the disease: all treated in one motion
Personal Care | Full updated guidance on beauty and style in hot weather
Tips | How to strengthen nails: simple tips every day
Methods | Hair - and still uncomfortable to sleep
DHA and Health | How to use funds for tanning
Rules | How to use funds for tanning
Creams | Treatment of stretch marks: the impossible - possible?
Oily and sensitive | Skin types and characteristics of care
Feet | Foot massage: relaxation and health improvement
Problems | Skin aging: three of the most common problems and their solutions
Cancer Risk | False Nails: benefit or harm
What determines the aging of the skin? | Aging skin - from what it depends on?
Forms | thermal underwear - keeps you warm and not only
From 40 to 60 | The rate of aging - for each test
Selection of brushes | Exfoliation dry brush: a pledge of soft, beautiful skin
Diseases | The most serious health problems for office workers
Objectives | Chiromassage - full control over the senses
How to | French manicure - high fashion effortlessly
Яндекс.Метрика
