Cream for hair removal - delicate hair removal - Ingredients
June 5th, 2013
  • Cream for hair removal - delicate hair removal
  • Ingredients
 Ingredients of creams for depilation
Creams, lotions and gels for depilation dissolve the hair shaft, acting on a fairly aggressive chemicals. They are very effective, but some people may cause skin irritation and allergic reaction Allergic reactions: how to understand why you tickle in the throat  Allergic reactions: how to understand why you tickle in the throat
 . It is therefore important to know what part of the depilatory creams.
 Ingredients | depilatory cream - delicate hair removal
Thioglycolate
Salts and sulfides thioglycolate - one of the most common ingredients of depilatory creams. Some of the products of Nair, for example, contain potassium thioglycolate - a substance with a sharp unpleasant odor damaging keratin, and thereby dissolving the hair. Sulfides barium and strontium have a similar effect and are much faster thioglycolates but they can quickly cause severe skin irritation and even cause burns.
Sodium hydroxide and calcium hydroxide
These materials help to create an alkaline environment, which is necessary in order that the depilatory cream effectively destroys the structure of the hair. Today most commonly used calcium hydroxide - it acts almost as well as sodium hydroxide, but more gentle on the skin.
Thinners
The purpose of use of a diluent is obvious - it dissolve ingredients depilatory cream, it can be achieved need easy-to-use product consistency. Currently, the most common diluent is water - it has a low cost, it does not irritate the skin, and fits well with many ingredients.
Emollients
Emollients include in the depilatory cream to loosen the aggressive effect on the skin of the other ingredients. As emollients can be used, for example, silicone oils and esters. The amount of such substances in the cream for depilation often exceeds the number of ingredients directly removing hair.
Additional ingredients
Apart from the above, in the depilatory creams may include flavorings, emulsifiers, coloring agents, preservatives, antioxidants, Antioxidants: the truth about the notorious benefits  Antioxidants: the truth about the notorious benefits
   and plant extracts.
Cream for hair removal - advantages and disadvantages
Pros:
Fast, cheap and relatively simple. Cream for hair removal can be bought in any store, and easy to use at home.
Disadvantages:
  • A strong odor. If you've ever used a hair removal cream, you are unlikely to something confuse their smell. Because of this, use the cream in a small enclosed space - for example, in the bathroom - can be extremely unpleasant.
  • The depilatory creams include harsh chemicals. They can cause more or less serious skin damage, especially when holding a cream on the skin too long. In some people, hair removal creams to cause burns, blisters, tingling, itching, rashes and severe peeling of the skin.
  • Short-lived results. When using the cream for depilation Waxing: the easy way to beauty  Waxing: the easy way to beauty
   slightly removed most of the hair than shaving, but still the hair above the skin surface appear the next day, at best - in a couple of days.
  • Light tingling while using the cream for hair removal is the norm. But if you feel a strong burning sensation, then you are either kept the cream on the skin for too long because you are allergic to one of its ingredients. In any case, the cream should be immediately rinse with cool water.
Article Tags:
  • depilation,
  • body creams
Massage Therapy - when it is needed? - For cancer patients
June 28, 2013
  • Massage Therapy - when it is needed?
  • Contraindications
  • Effectiveness
  • For cancer patients
 massage therapy for cancer patients
Massage Therapy for Cancer Patients
For people with cancer therapeutic massage may be an additional type of therapy that helps improve overall health. In particular, the massage helps to cope with stress How to beat stress? Create an oasis  How to beat stress? Create an oasis
   and anxiety Anxiety - how to distinguish normal from disease?  Anxiety - how to distinguish normal from disease?
 , Ease headaches and other pain, improve sleep Dreams: how to understand our dreams  Dreams: how to understand our dreams
 For cancer patients | Massage Therapy - when it is needed?
How is the massage
Before the start of the session the therapist will ask you a general question about health, lifestyle and medical history. If he has any doubt that you do not massage is contraindicated, it may ask the contact details of your doctor. This is normal practice as a masseur lays the responsibility for the health of the client. For its part, you have to pre-talk to your doctor about whether you can do massage, and whether it will help accelerate the growth of the tumor.
If you choose a shiatsu massage, during the session, you will lie on a soft mat on the floor; This type of massage do when the client is fully clothed. Most other types of massage do when a customer is on a special couch; previously you will need to take off everything except underwear. Then, the therapist will cover your body sheet or large towel, leaving open only the part of the body, he would massage right now. As a rule, if you do a full body massage, the first half of the procedure you lie on your stomach, the second - on the back.
Typically massage lasts one hour, but the duration may be different, depending on the technique used. The strength of the pressure at which the masseur, also depends on the type of massage, but in any case, if you feel uncomfortable, immediately report it to the masseur.
Massage therapy and cancer: research results
Numerous studies indicate that massage helps ease the symptoms that accompany cancer, such as pain, nausea, anxiety, depression, stress, fatigue.
Participating in the study of women with breast cancer who are regularly massaged, less than the others suffered from physical discomfort and mood swings. It has been found that the therapeutic massage can even improve the condition of patients with metastatic cancer - it reduces anxiety, and to some extent reduces pain.
Side effects
Most people, including cancer patients, massage not cause any side effects. However, some people after a massage feel dizzy, tired and thirsty. Masseur should not rush you after the session - you should leave the room when you feel well enough. After the massage, it is recommended to drink plenty of water - not only to cope with thirst, but also to stimulate the removal of toxins that are released from the body tissues.
Contraindications
People who have cancer are broken apart, heart disease or arthritis Arthritis - a variety of forms and complications  Arthritis - a variety of forms and complications
 , Massage therapy may be contraindicated. Cancer patients is not recommended to do a deep tissue massage - safe for them more forgiving massages.
Some people fear that due to the stimulation of soft tissue cancer cells start to migrate to other parts of the body. While no study has proved that this is possible.
If you're going through radiation therapy, remember that it is impossible to massage areas of the body that are affected by the radiation treatment.
  Galina Romanenko
Article Tags:
  • massages
Яндекс.Метрика
