Burdock oil - helps damaged hair
November 6, 2008
  • Burdock oil - helps damaged hair
  • Benefit
  • Properties
  • With red pepper
  • With propolis
  • With nettles
  • Application
 Burr oil
   Burdock oil has been used for centuries as a natural remedy for hair care, as well as a means to combat hair loss. This oil helps to reduce the irritation of the scalp and generally improves its condition. As a result, hair becomes thicker, shiny and strong. Burdock oil, in particular, it contains phytosterols, normalize the functioning of hair follicles and sebaceous glands. Proponents of alternative medicine and folk treatments used burdock oil to prevent baldness, for the treatment of skin diseases and symptoms of rheumatoid arthritis. There are also proponents of the view that the burdock helps to prevent some types of cancer.
Most of the properties of burdock oil has not yet been sufficiently studied by medical professionals. Nevertheless, the experience of many people talking about its benefits for the body. It is known that fitosreroly - variant molecules of cholesterol absorbed by the body in very small quantities, but play a very important role in reducing the total cholesterol in the blood and thus preventing cardiovascular diseases.
 alt
Contraindications
Reception burdock oil inside is not recommended for patients with diabetes because it lowers blood sugar Blood sugar - one of the main indicators of human health  Blood sugar - one of the main indicators of human health
 alt
Pregnancy and lactation
Pregnant women and nursing mothers to oral administration of burdock oil is highly recommended to consult a doctor. In general, it is a natural remedy is safe, but in some cases it can harm the baby - for example, if he has an allergy to any substance as part of burdock oil.
 alt
How to use burdock
Burdock oil is discharged as a liquid for oral administration; It is also used topically. Oral administration of burdock oil is recommended for certain diseases of the stomach, digestive problems; It is also a good tonic remedy. Before taking the oil inside the need to consult with your doctor.
There are many ways to use burdock oil as a means to improve the growth and appearance of hair. For example, heat the oil to a temperature slightly above normal body temperature and rub his gentle massage into the scalp. Then you need to put on the head with a shower cap, wrap head with a towel and leave the oil to soak for an hour or two. Then wash your hair should be gentle shampoo and warm water. This tool is very effective when the hair is dry, damaged, stained, do not grow, fall. Burdock oil helps cure dandruff, the cause of which is a dryness of the scalp.
Burdock oil can also be used as a massage oil. Pre-need to warm up a small amount of oil to a temperature of about 40C.
Because of burdock oil you can cook and such a remedy for hair care. Mix in equal proportions of half a teaspoon of essential oils of rosemary, basil and lavender The healing properties of lavender - not only pleasant aroma  The healing properties of lavender - not only pleasant aroma
 . 5 drops of this mixture, mix with one tablespoon burdock oil and one tablespoon of aloe vera gel Aloe - its amazing healing properties  Aloe - its amazing healing properties
   Vera. Careful circular motions, rub this mixture into the scalp, leave for a few hours, and then wash your hair. This tool is perfectly stimulates hair growth, making them healthier and removes dandruff.
For oily scalp using burdock oil can be massaged for 5-10 minutes, but leave it for a long time it is not recommended. It can clog the pores, which is likely to lead to excessive hair loss.
 alt
Does burdock
Burdock oil - a natural herbal remedy for hair and wait for him for a moment he does not have a positive effect.
Today the cosmetic industry are produced and more effective means to restore hair, but whether to ignore a proven remedy for centuries as burdock?
 alt
The action of natural cosmetics
A feature of the actions of all natural cosmetics (including burdock oil) is that they are very slow. And as previously there were no other products than those that nature has given us, and no one was waiting for them instant effect. Women over the years have used burdock oil to strengthen the hair with a few interruptions, and realized that the only way to achieve the desired.
In India, for example, traditional medicine recommends that women use different types of oils to purify, rejuvenate and restore the beauty of the skin of the whole body. To restore hair growth and beauty are also encouraged to a certain set of oils, including burdock. However, such procedures are carried out over the years and therefore have the desired effect.
What happens when applied burdock oil? First and foremost is the cleansing of the scalp and hair shafts from toxic substances which can not be removed only by washing the hair. To this end, as part of burdock oil has a special ingredient - the adsorbent inulin, it was he who cleanses the skin and hair, depositing all harmful and unnecessary on its surface.
When the skin is cleaned, a suction process starts in its cells the nutrient substances contained in the burdock. A lot of them, it's the vitamins, minerals and bioflavonoids, which stimulate the "push" to speed up the metabolism, trying to make them more active. The only way to improve the condition of the hair roots. But within an hour (as usually is the procedure) is not so many nutrients enters the cells and stimulate metabolism very quickly and they could not. These substances are simply part of the substances participating in certain biochemical processes, together constituting cellular metabolism Improves metabolism and losing weight without dieting  Improves metabolism and losing weight without dieting
 . With long-term systematic use of natural resources steadily improving metabolism and skin cells are no longer in need of additional "feeding", so there is a break in treatment. But after a while the cells again, requires more power, and a new course of treatment maintains the state of the hair at the same high level.
 alt
Rapid effect
The modern woman does not want to wait for the effect of months and years, it s usually needed immediately. The cosmetics industry is always going to meet potential buyers. Therefore, in special laboratories inventing new nutrients for hair restoration. Or use natural products of vegetable or animal origin, but in combination with the chemicals that help to quickly deliver them to the cells of the skin and quickly penetrate the cell membrane. As a result of the activation of metabolic processes in the cells of the skin occurs much faster than using purely natural herbal preparations.
But a constant significant stimulation of the skin cells do not always end well - they simply fail to respond to the impact, the metabolic processes in them slowed down and thus deteriorating condition of the scalp and hair. Therefore, effective beauty products for hair restoration should be used strictly in accordance with the instructions supplied. Developed such instructions after the necessary testing of cosmetic products, so provide a very necessary information.
So what to do, it is not efficient to use expensive cosmetics? To refuse such cosmetics (of course, if resources permit) is not necessary, but it is better not to use it in accordance with the advertisement, and after consulting a dermatologist, cosmetologist, which will select the means of the most appropriate type of skin and hair of the person.
By using effective modern cosmetics for hair restoration should not be ignored and traditional burdock, its courses can be alternated with courses of modern creams and gels designed for the same purpose.
Too much effective cosmetics in general is bad for the skin, it gets tired of constant stimulation and is therefore not surprising that such skin suddenly starts to lose its properties and age rapidly.
Essential Oils: What is the benefit or harm from the use of
Properties | Burdock oil - helps damaged hair
Propolis | Burdock oil - helps damaged hair
Applications | Burdock oil - helps damaged hair
With red pepper | Burdock oil - helps damaged hair
Pheromones - the road to the heart of a loved one is through the nose
Aromatherapy - heals the soul, but not the body
The use of amaranth oil - the Aztecs know a lot about plants
Allergy to Tribestan - not often, but found
Camphor and its beneficial properties: a popular, but not safe
Aloe - Recipes for health
Aromatic oils for the hair - a nice departure
Evening primrose oil - an essential nutritional supplement for women
Aroma: a unique atmosphere in the house
The use of essential oils in cosmetics - what factors should be considered?
Essential Oils - whether they will help in a difficult moment?
Carnation: exquisite aromatherapy
Recipes for Health | Aloe - its amazing healing properties
In cosmetics and medicine | Aloe - its amazing healing properties
Extract | Aloe - its amazing healing properties
Essence: essence of tender plants
Attar: natural perfume oriental princesses
At home | Incense - echoes of ancient rituals
Aroma - to solve the problems of the body
External application | Wheat germ oil - undeniable benefits
Cedar oil - strengthens the immune system
Dihydroquercetin - description phytopreparation
Sandalwood: an essential oil with an ancient history
Essential oils and their use in medicine
Air freshener - how much it is safe?
Tribestan and alcohol - it is not necessary to combine
Mud - a pleasant and useful procedure
Myrtle oil: a wonderful gift rainforest
Mirra - Health and Beauty
Jojoba: valuable oil with a bunch of errors
Treatment with aloe vera - the power of nature
The use of essential oils for skin and hair
Essential oils for aging skin: aromatic rejuvenation
Essential oils: sinusitis - the possibility of aromatherapy
Treating sinusitis sea salt - a natural therapeutic agent
Tribestan for men - in disorders of sexual function, and for the prevention of atherosclerosis
Forms | Benefits of essential oils for skin and hair
Яндекс.Метрика
